Read geofences from file
To read geofences from a file, use the command exchange/import_zones_read:
svc=exchange/import_zones_read&params={"eventHash":<text>}
:!: Current request can't be executed simultaneously with any request from this chapter and following requests:
Parameters
Name Description
eventHash event name, which will be generated after reading geofences (optional parameter)
To upload a file with geofences, use a POST request with multiple contents (multipart/form-data).
For example:
Request URL: https://hst-api.pro.transcontrol.ru/wialon/ajax.html?svc=exchange/import_zones_read&sid=8157df114c0e601f0f31091c3c2ac53d
Request Method: POST
Connection: keep-alive
Content-Length: 1281
Cache-Control: no-cache
Content-Type: multipart/form-data; boundary=----WebKitFormBoundaryzmBiAUFQVzA8mRkx
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Charset: windows-1251,utf-8;q=0.7,*;q=0.3
Accept-Encoding: gzip,deflate,sdch
Accept-Language: ru,en-US;q=0.8,en;q=0.6
------WebKitFormBoundaryzmBiAUFQVzA8mRkx
Content-Disposition: form-data; name="params"
{"eventHash":"jUploadForm1372771850650"}
Content-Disposition: form-data; name="eventHash"
Content-Disposition: form-data; name="import_file"; filename="geofence.kml"
Content-Type: application/vnd.google-earth.kml+xml
------WebKitFormBoundaryzmBiAUFQVzA8mRkx--
Response
{}	/* empty object if execution successful, if not - error code */
To be sure that geofences has been read, you can execute the command Events:
	"tm":<uint>,				/* current server time (UTC) */
	"events":[
			"i":-1,
			"d":{			/* data */
				"hash":<text>,		/* upload is complete */
				"zones":[<Object>]	/* array of geofences read */
